06-09-2016 01:02 AM
Hello
I am creating a vi to generate 1PPS signal at NI DAQ USB 6008 from PC clock which is synchronized with NTP server. And transmit this signal on TIC.
I am new to LabVIEW, so kindly help me.
Thanks in advance.
Abhinav
06-09-2016 01:15 AM
06-09-2016 01:15 AM
Hi abhi,
LabVIEW comes with a lot of examples.
There are also example VIs showing how to output digital signals (like your pulse) using a simple USB600x device. Just open this example VI, study and understand it, then apply your logic to output a pulse each second…
Remark:
When asking questions in the forum you should not use so many abbrevations. Try to explain as much as possible!
(What exactly is "TIC"?)
