06-18-2013 12:49 PM
06-18-2013 12:51 PM
06-19-2013 09:08 AM - edited 06-19-2013 09:12 AM
The Facebook discussion board is just a pilot and that functionality is not available yet (as to my knowledge). You will have to use the actual forum thread to add attachments. You can click the arrow just to the right of thread topic in the Facebook thread and that will take you to the ni.com/forums thread. Or you can navigate here:
Having a look at your VI would help to clarify the error handling issue.
06-19-2013 10:09 AM
Attached is the .vi I was working on -> couldn't edit my original question for some reason.
06-19-2013 11:04 AM
Could you also include the SMS.vi file?
06-19-2013 11:10 AM
Have you heard of LabPython? It might help you avoid using System Exec.
06-19-2013 11:39 AM
The "standard error" output will return the errors from the program you calling, while the "error out" output will return errors that have occured in LabVIEW. There are 2 of these outputs in order to differentiate between errors occuring in the LabVIEW program and errors occuring in the program being called via the System Exec VI. So if you want to parse the information from the "standard error" output string to get the error out of the other script.
