04-28-2014 06:07 AM
Hello.
I want make something like this http://sine.ni.com/cs/app/doc/p/id/cs-13831.
I have garmin GPS 10x receiver and it works.
Google API works correctly but i have problem with LLA data from GPS sentences.
I have really no idea what is this SubVI in no error frame.
04-28-2014 06:25 AM
04-28-2014 08:29 AM
It appears to be a VISA resource being sent into the acquisition sub vi. It seems they are simply talking to the GPS receiver. Do you have more documentation on your equipment? The Garmin receiver is just an antenna, you need the actual processor which is communicating and receivng the NEMA string.
It appears they are simply breaking the string down and sending out the Lat and Long as doubles. I did this many years ago on a simple ATMEGA. Just need to get the protocol get her going.
Like Thoric said, they may have the code availble as well but there should be a known communication process with your hardware and your goal is to use that to get the info from the GPS sats.
Best,
Adam
04-28-2014 09:10 AM - edited 04-28-2014 09:14 AM
My receiver have processor and sending NMEA 0813 GPS sentences.
No i dont contact the author, but i try it.
i have only this.
Now I need to split string into array.
04-28-2014 09:27 AM
04-29-2014 10:08 AM
it's work.
now I need read 2. and 10. value from output string array and convert it to dbl.
I can't find any example and i have no idea how make this.
