Hello Emilie,
Thank you for answering. I think the problem was that I had an older version of NI-VISA. I updated it and now an older version of the driver works on my computer. However, I tried to install labview 7.1 and now I get a similar problem. This is what I did:
-install labview 7.1 with driver update (NI-VISA, NI-DAQ...etc.)
-install srps3xx drivers from labview 7.1
-try out the "getting started" vi.
and then I get an error message again: which states that the program has trouble initializing the device due to "either a VISA code library could not be found or opened". I checked a bit inside the getting started vi and I noticed that the error occurs at the initialize command.
I'm not sure what to do, should I just reinstall the whole thing? (It might be possible that since I had a previous version of labview on the computer?
Thank you.
