02-26-2014 10:34 AM
I created a VI on a windows 7 machine with a monitor resolution of 1280x1024. Under the Vi Properties->Window Size, I checked the "Maintain proportions of Window for different monitor resolutions", and under VI Properties->Window Run-Time Position, I chose "Centered" for Position and "Primary" for Monitor. I built an EXE. When I start the EXE on the Labview development machine, it is centered and looks good.
I copied the EXE to my laptop with a 17" screen and resolution of 1600x900 (WIndows 8 machine). When I start the EXE on this machine, the front panel window shows up with part of it off the viewable area to the left. I am able to move it to the right to see the whole front panel.
My question is why wasn't it centered on my laptop and completely viewable like it was on the development machine? What did I forget to check in the VI properties?
Rick
02-27-2014 10:13 AM
Hi RPluth,
Make sure that you also check the box for "Scale all objects on panel as the window resizes." If that doesn't work make sure that you do not have the window maximized on your development machine.
02-27-2014 11:07 AM
Thomas N,
Thanks for your reply.
I do have "Scale all objects on panel as the window resizes." checked, and the window is not maximized on my development machine.
When it opens on my laptop (ie. non-development machine) it looks correct size and content wise. It's just that it's about 25% off screen to the left even though I chose "Centered" for my position.
RPluth
02-28-2014 11:28 AM
Hi RPluth,
Can we try checking the box for "Maintain proportions of window for different monitor resolutions" under the Window Size category.
02-28-2014 01:49 PM
Thomas N,
I do indeed have that checked, yet still it is off the screen to the left a bit and not centered.
Rick
03-03-2014 06:23 PM
Hi Rick,
Try running this application and let me know if it centers on both computers.
