NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
JamoBryant
Frequency domain of Xbee data
[ Edited ]
Hello, this is the first time I have used the forum so please be gentle.
I have adapted a Vi to interpret a data packet from an Xbee wireless module. I have successfully interpreted the 'analogue' portion of the incoming packet and displayed it in the form of a chart depicting the time domain signal.
However, as hard as I try, I have had absolutely no success when attempting to display that exact same signal by means of frequency domain analysis.
I have attached a picture of the Vi in the hope that someone may be able to help. I appreciate any comments, thank-you.
Active Participant
Puneet_K
Re: Frequency domain of Xbee data
Can you please post your xbee data & describe bit more about how you want to see it in both domains.
CLD 2012
Member
JamoBryant
Hi, thankyou for your reply. The Xbee module transmits a packet of data containing 22 bytes. The value of '7E' signifies the start byte of the data packet which I am using to index the other bytes.
At this point I am only interested in the 20th and 21st byte which denotes the Most Significant Byte & Least Significant Byte of a analogue sample. I have added these two bytes together and have successfully plotted them by means of the chart depicted in the Vi.
I desperately wish to use a chartto display the same value by means of spectral analysis so I can see what frequency components exist at certain amplitudes.
My analogue sample represents a vibration signal.
I hope this makes sence and appreciate your interest!
James
Member
JamoBryant
This is what the data packet looks like with a byte on each line. The bytes are depicted as decimals values here but are actually HEX in reality.
Member
JamoBryant
I have tried many things. the closest i can get is to get a FFT graph where the amplitude along the side varies but no plot / line shows on the graph. I only need to identify frequencies below 20 Hz. The time domain graph works fine (maybe slow).
Please, if anyone can help, it would be so appreciated. I have been working on this for so long and cannot make anymore progress.
James
Active Participant
GovBob
I'm no expert and I can't look at your latest vi as I only have access to LabVIEW 2010, but judging from your diagram I see no timing information being collected. In your diagram the waveform chart looks like it is just using a default timing. How fast are you collecting these samples? You need to create (recreate) the waveform using your samples,dT and the build waveform primitive.
Hope this helps.
Using LabVIEW 2010SP1 and TestStand 4.5
Member
JamoBryant
Thanks for the reply. Im very new to labview.
I have constructed a waveform as shown in my diagram. "waveform chart 2" shows the signal in the time domain.
Is this what you meant? The Xbee samples analogue values @ 1k samples per second, but this may be not 100% acurate after transmission of the data. I think I will be able to tweak the accuracy of the system using a known waveform at the input and adjusting the sampling until the output is satisfactory.
Now. It can be seen that I have attempted to get a graph to depict the frequenct components of the newly created waveform but the "result" graph returns no results??? all that i see is a change in the amplitude numbers @ the side of the graph but no plot??? Im guessing this is not the correct method to achieve frequency analysis.
Any thoughts?
Thanks again!!!!!
James
Member
JamoBryant
[ Edited ]
Sorry, doesnt seem like my picture has shown up.
I have further attempted to display the frequency data, but no matter the signal. the frequency plot remains @ zero??
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
