Force to buttons to default values at start
I have a radio button that I would like to go to the default value (Null) at start.  The problem is that if I forget to clear the button/action after a run and start the VI again the "action" gets invoked,,,, not good.
I swear I saw a way to force a VI to reinitialize all values etc,, at start.
(2,516 Views)
HI SciDesign
To come out of this problem right click on that radio button and select allow No selection and initially pass 0 to that radio Button i think this will help you.....
Santhosh M
(2,505 Views)
You can write any value you want to the radio button's local variable (no need for 'Allow No Selection' unless that is what you want) or use the VI method called Default Vals.Reint All. You can do this at the beginning or end or your program
(2,503 Views)
Thank you all!  I was able to get what I needed by writing to the Local Variable in the first frame.
(2,462 Views)
