07-01-2016 02:11 PM
I'm not sure of your question. Are you asking how to ensure that Reverse(3) becomes 30000?
As you've probably realized, when designing an algorithm such as Reverse, you need to think carefully about what you want to do (and maybe take pencil to paper and work some examples). For example, you could define Reverse as "Reverse the digits", in which case Reverse(3) = 3, or as "Reverse the digits of an N-digit number", which is a different function, Reverse(3,5) = 30000. If you think about the difference from a standpoint of loops, the criteria for deciding how many loops to run are different for these two algorithms.
How are you stopping your loops now? How should you be stopping you loops? [I'll bet they aren't the same thing ...]
07-01-2016 02:31 PM
Are you saying that the largest number you can enter into your start number is 32767? Is it a I16? If that is your problem try I32 instead.
In C terminology it's the difference between short and int.
07-01-2016 02:46 PM - edited 07-01-2016 02:46 PM
Asuming that you correctly set the entry limits for the number of digits, reversing a fixed number of digits is actually easier because you can use a FOR loop.
(I would stick to unsigned integers though to avoid surprises.)
07-02-2016 01:32 AM
Do you know how to find the palindrome number using labview with specific range ? for example i want find the palindrome number range from 0 - 1000000 .
07-02-2016 02:37 AM
07-02-2016 02:42 AM
@altenbach wrote:
Yes.
I dunno how to display the value come out. T.T
07-02-2016 10:50 AM
Ambrose1464 wrote: I dunno how to display the value come out. T.T
So you know how to find the palindromes but don't know how to display them? Just use an array indicator on the front panel and the rest should fall into place. Where does the "value" come out of? Can you show us the code you have so far?
07-02-2016 09:10 PM - edited 07-02-2016 09:10 PM
@altenbach wrote:
Ambrose1464 wrote: I dunno how to display the value come out. T.TSo you know how to find the palindromes but don't know how to display them? Just use an array indicator on the front panel and the rest should fall into place. Where does the "value" come out of? Can you show us the code you have so far?
This is my code so far. I have done 1 is check whether this number is panlindrome or not. the below that code i have no idea how to do it for checking the palindrome number in given range and dispay it out.
07-02-2016 09:53 PM - edited 07-02-2016 09:55 PM
Suppose you have a LabVIEW sub-VI called "Reverse" that reverses an integer's digits. In particular, the reverse of an n-digit integer is another n-digit integer, so Reverse(5) = 5.
Now write another sub-VI that takes an integer and returns a Boolean if the integer is a Palindrome (call this sub-VI "Palindrome").
Do you know how For loops work to create Arrays? Do you know about Indexing tunnels? About the Conditional Terminal on an Indexing Terminal? About the function of the Index variable (in the little blue box in the lower left corner of the For loop with "i" in it? You can get the answer to "List all the Palindrome numbers from 1 to 100000 (or whatever number) with a For Loop and the Palindrome function you developed in Paragraph 2.
Why do this with sub-VIs? if you write code that does "one thing", it is easier to convince yourself and others (and maybe prove it). So "Reverse" only "reverses" an Integer, "Palindrome" only detects if a number is a Palindrome, and a simple For loop with a Palindrome function inside it wired properly to an indexing terminal is self-explanatory (and self-documenting).
07-02-2016 09:55 PM
Do the check inside the loop. Use a conditional tunnel to build an array of values if it is a palindrome.
I don't understand why you wired upper limit to the N terminal, and use lower limit. You are just going to figure out if the lower limit value is a palindrome a number of times in a row to equal "upper limit".
Try running your code with Highlight execution turned on so you can figure out how it works.
And use block diagram cleanup.
