03-12-2010 01:17 AM
Hi All,
Have anyone used NEC PG-FP5 Flash programmer with LabVIEW or Hyper terminal.
03-16-2010 04:35 PM
03-16-2010 11:01 PM
I am trying to Flash a microcontroller using FP5 programmer.
I have HEX file which I will download to the FP5 memory. From there I will flash this file to Microcontroller.
I am trying to use VISA for communicating with the device using LabVIEW.
03-17-2010 09:17 AM
I considered using VISA in my application, but could not since I have to change some of the data in my hex file.
My programmer did have a bunch of commands that I could use to automate the flashing process with RS-232. Does your manual describe anything similar to that?
03-17-2010 11:21 PM
The FP5 supports communication commands using serial communication. The list of all commands are given in the usermanual. I have checked most of the commands using Hyper terminal.
I was trying to download files from my PC to FP5 memory. I am facing problem during the download of HEX file.
There are 3 files to be downloaded to the FP5
The order of downloading is as shown above.
I am able to download *.pr5 & *.esf files, but the HEX file download is showing ERROR.
The screenshot of the Operations that I have performed using Hyper terminal is attached to this post.
Have anyone encountered this problem before? Please suggest a solution...
04-04-2013 04:21 AM
We can see on your image that you have not the good pr5 file loaded.
You can download it at Renesas.com adapted to your µC.
Further you need to tape instead of progarea 0 --> progarea clear 0
04-04-2013 05:43 PM
hi, i have to do the same thing, send commands to fp5 from labview, could you help me please?
04-04-2013 05:44 PM
11-28-2013 08:21 AM
ihave same problem !!!
09-27-2014 03:44 AM
I have also the same problem, I want send Hex File to PGFP5 with serial port by using the command lod with Labview, I receive this message response from the PGFP5:
lod
preparing storage ...... PASS
NOW loading.....
Aborted in line :16
Any help?
