03-04-2014 07:12 AM
I am relatively new to curve fitting in LabVIEW. I am currently working on a project where I gather data from over RS485. This data comes from a sensor which exhibits a first order system behaviour and thus has a time constant equal to RC. Thus, the data that I am gathering, y, is of the form:
y = k(1 - e^(-t/T))
where T is the time constant which I need to find. I have tried using Exponential fit but obviously I cannot since it fits the data in a different way than I want it to.
How can I fit such data in LabVIEW and then find the time constant from it? I have searched this forum multiple times but I didn't find a satisfactory solution for my question. I have also researched the subject on the internet to no avail. Please help!
Thanks.
03-04-2014 07:43 AM
y = k(1 - e^(-t/T))
Thanks.
"I have tried using Exponential fit but obviously I cannot since it fits the data in a different way than I want it to. "
Please enlighten the obvious for me. [From the LabVIEW Help screens] The exponential fit VI fits points to the following equation:
y[i] = aebx[i] + c
Your equation, y = k(1 - e^(-t/T)) easily rearranges to y(t) = -k e^( (1/T) t ) + k , so a=-k , b=1/T , c=k=-a (one less variable to solve for!)
Looks the same here.
Cameron
06-13-2017 12:45 AM
Since I am too new to this problem, I was facing similar trouble. The problem can easily resolved by selecting appropriate parameter bounds as input. For example default min max values of offset i.e in your case k is 0. This needs to be changed to appropriate values to obtain required graphs.
Athul
