01-27-2014 04:19 AM
Hi Everyone,
Does anybody knows how, from a given LabVIEW project with several target (Computer, Compact RIO, sbRIO, PXI,...), what is the software component and drivers required to run fully and properly the VIs the project contains assuming the project VIs run successfully on the developper computer and that I have the defined project Hardware components at my disposal.
What do I need exactly to report as NI required software components.
Thank you Guys...
01-27-2014 05:38 AM
Hi
With Labview 2013 the project installer build can automatically add all additional installers to your installation package.
I don't think the process is perfect but it should certainly help. More details here ...
http://zone.ni.com/reference/en-XX/help/371361K-01/lvdialog/addl_install_info_db/
