I'm used to VB and I am having trouble getting my head around some LabVIEW concepts.
If I have 2 combo boxes on a form, how do I fill the second one based on the first?
I have attached what I have done so far (you can probably see how new I am to this!)
The VB code would be
Select Case cboLineSize.ListIndex
Case 0 'GR900
cboLength.Clear
cboLength.AddItem "125 mm"
cboLength.AddItem "15 mm"
cboLength.ListIndex = 0
Case 1 'Type-N
cboLength.Clear
cboLength.AddItem "7.5 mm"
Case 2 'PC-7
cboLength.Clear
cboLength.AddItem "100 mm"
cboLength.AddItem "7 mm"
Case 3 'PC-3.5
cboLength.Clear
cboLength.AddItem "75 mm"
cboLength.AddItem "16 mm"
cboLength.AddItem "4 mm"
Case 4 'K-connector
cboLength.Clear
cboLength.AddItem "60 mm"
cboLength.AddItem "10 mm"
cboLength.AddItem "2.5 mm"
Case 5 'PC-2.4
cboLength.Clear
cboLength.AddItem "50 mm"
Case Else
MsgBox "Not an option"
Exit Sub
End Select
Message Edited by opticyclic on 05-16-2005 01:00 PM
