02-03-2010 05:08 AM
Hello All,
I m confusing how to transfer data file which is generated in cRIO while runnig an application. I want to transfer the file to IPC on which there is one SCADA application is runnig which is read that file for post analysis of data. In IPC there is no any LabVIEW code running or LabIVEW application and I don't want to do that too. I jsut want to transfer data by cRIO itself and after transfering need to delete that file too. So how do I do that..? Any idea would be appriciable..!!
02-03-2010 05:25 AM
02-04-2010 06:18 AM
02-07-2010 10:45 PM - edited 02-07-2010 10:46 PM
Well, the best way to transfer data from CRIO is using TCP IP. You can use either the Etherent or the Serial port of the CRIO to communicate with the external device. You should be aware of the protocols your device follows and program your CRIO code that way!
