Fatal Internal Error LV2010-DS1
Hallo All, I was installing LabVIEW from the 2010-DS1 Distribution kit (LV2009-SP1), after the whole installation process, I started LabVIEW and I've seen the Error : Fatal Internal Error "objmgr.cpp", line 2133...like in the attached image. I'm working with a NEW Dell Precision M6500 with 8GB RAM and Windows 7 (64bit). How can I solve the problem? I've a super Notebook and the latest LV revision...but nothing work! Thanks Fabio
(3,050 Views)
(3,022 Views)
Ciao Fabio,
your issue might be related to user account policies.
You need to have administrator privileges to use LabVIEW. If you're not the administrator you would need at least access to these 2 specific folders:
 C:\Documents and Settings\All Users\Application Data\National Instruments
C:\Documents and Settings\All Users\Documents\National Instruments
Hope this might help.
Andrea
Andrea N.
Principal Applications Engineer - Semiconductor EMEA
National Instruments Italy
Certified LabVIEW Architect - Certified TestStand Architect
(3,005 Views)
I have the same problem but I couldn't solve it. I am the admisistrator and I have the privileges on the PC.
Can you help me, please?
Thank you
(2,694 Views)
hello, when I met this error :  Fatal Internal Error "objmgr.cpp", line 2343.. I went to C:\Program Files\National Instruments\LabVIEW 2010\resource\objmgr and eliminated the file named sessionReference.rch. Finally I can use Labview perfectly
I hope this is helpful
(2,637 Views)
