Fatal Interal Error: LvVariant.cpp", Line 5677
Has anyone seen this error before?
Labview Version 8.2
You will lose any unsaved work. For assistance in resolving this problem please relaunch labview or contract NI
I was running an .exe on a clients computer when I saw this message at start up. It happened twice (once on two different computers at about the same time) and then I never saw it again.
Any idea what could cause this?
Matt
(2,452 Views)
Matt,
The error you saw was an internal error that LabVIEW reported, as you might have guessed.  I personally haven't seen that before, and I did a search and didn't find any other reports of the same error.  Judging from the name I would guess it has something to do with the Variant data type, but this could be caused by any number of things.  Since you were running this as an EXE there probably isn't a logfile that is created, but you could check in the My Documents/LabVIEW Data folder to make sure.  It might be a system configuration issue that caused this error that was fixed after you saw the last error.  If you do find the logfile post it here, otherwise keep us updated if you see this again.
Thanks!
Andy F.
(2,439 Views)
