05-26-2005 09:41 AM
08-10-2005 02:49 AM - edited 08-10-2005 02:49 AM
I am using FAMOS, version 3.2. I have created FAMOS files according to the .dat file description in the imc Curve Manager manual version 3.2, chapter 9 (File Format).
I use subVIs for creating the |XX keys for the FAMOS file format. Attached example FAMOS Key CB.vi. I have corresponding VIs for each key that is needed for the FAMOS file format. The file is created in a main VI that concatenates the key strings from each subVIs and writes the complete string to a .dat file using the Write Characters To File.vi (found from the File I/O subpalette in the block diagram Functions palette).
Message Edited by Tom C on 08-10-2005 02:49 AM
07-12-2006 02:26 AM
hello,
have you realised other programm to read a FAMOS file (in .dat) ??
because I try to read a famos file but when I watch it in a graph, it's not the same signal that in FAMOS .
thank you in advance
Xavier DECLERCK
I'm French so excuse me for the faults
