Failure:"Linker.cpp"' Line2917 and Line3338
Most of the time, I try to save my work while I am working on VI, My computer (Windows XP, LabView 6.1)crashes with the failure: "Linker.cpp", Line 2917 or Line 3338.
(2,257 Views)
Hi Roman!
Currently, I have not found any documentation on this specific Linker error (Line 2917 or 3338). Does this happen when you try to save all of your VIs? Is this only happening with specific VIs? If this is only happening with a specific VI, can you make the VI as small as possible and then attach it to your post? If you can do this I will try to reproduce the error and troubleshoot it further.
Thanks Roman!
Travis H.
Travis H.
LabVIEW R&D
(2,248 Views)
