FTP "PWD" and unescabe double quotes
HI
I am using LV8.2.1 and the internet toolkit.
There is a FTP function called "PWD"(print working directory) who I think got a bug.
It don't put out the working direktory.
It take the reply text ( ex: Current working directory is "fs")and use the subVI "unescabe double quotes.vi" to remove the quotes, but this subVI need to have a string where the hole text is surrounded with double qoutes.
The FTP "PWD" function send a string like this( ex: Current working directory is "fs") to the subVI and that result in an empty string out.
Take a look at the attached pictures.
regards Bjarne
(2,510 Views)
Hi
Any comment to this post?
I just find out that the bug is in LV8.6.1 too.
regards Bjarne
(2,474 Views)
Hi Bjarne,
Is this VI called FTP Directory Listing VI in LabVIEW 8.6.1?
Could I get you to explain in little more detail why you think there is a bug in this VI?
A code example that illustrates the erroneous behavior is always appreciated.
Eirikur Runarsson
(2,381 Views)
Hi Bjarne,
what FTP server are you using? It seems your FTP server doesn't follow the protocol. The response to a "PWD" should be like this:
257 "/path/on/server" [is current directory.]
It should start with the 257 code, followed by the path surrounded by double quotes.
If the FTP server follows the protocol the PWD VI works just fine.
As a workaround, you can use the "reply string" output of the PWD VI and use a match pattern to find the portion string between double quotes.
Daniel
Message Edited by dan_u on 03-11-2009 02:34 PM
(2,375 Views)
