05-02-2016 10:21 AM
Have you looked at the D2XX Programmer’s Guide? It looks like FTDI also has some good examples of using their drivers. You can take a look at how they structure their function calls and then structure your LabVIEW code same way.
Also, what kind of instrument are you trying to connect to? If it’s possible to use NI-VISA I recommend going down that route as it would be a more robust solution.
Additionally, since this thread is a little old I recommend making a new post specific to your own question.
02-14-2018 06:43 AM
Hello Mac,
I'm not sure if you're still active in the community, but wanted to put the message here.
I'm also looking to use two GPIOs (GPIO2 & GPIO3) in the FT4222H device after working out for I2C. Looks like whatever I read is not proper values. Had you solved this issue? If so, could you please share your driver if you have now?
Ajay.
02-15-2018 12:17 AM
I once shared code and got a thank you and no kudos.
So I can understand why people not share their code.
02-15-2018 06:17 AM
02-15-2018 03:21 PM
Hi Ajavignesh - I would recommend also posting your question on a new thread to get more visibility in the community! You can reference this post so that people know what has already been discussed.
02-18-2018 07:13 PM
I have successfully used this FT4222H in my application and have written an article about few bumps on the road I faced in here.
https://www.digiajay.com/2018/02/19/how-to-use-ftdi-ft4222h-in-labview/
Please make use of it.
