FSK Modulation/Demodulation
I am new to LabVIEW and have been learning using tutorials that I find in here.
I am trying to create a VI that will input an audio signal from myDAQ and do FSK modulation then demodulate and output using my laptop speakers.
Eventually I would like to send the modulated signal to another computer, but for now I am only learning how to do this. And possibly have a file with the history of the sent signal.
I have tried to do this without using the modulation toolkit, but I just ended up with loops that would take minutes to modulate for only a few seconds. So that didn't work as expected. Since I have the modulation toolkit I tried to use it looking at what others have done here, but I am not sure how to make it work exactly, and I couldn't find many tutorials about the modulation toolkit.
Can you guys please help me?!
I am attaching the VI that I created.
And if something doesn't make sense, please help me fix it, and understand why.
Message 1 of 19
(10,014 Views)
There is a HELP DOCUMENT available for the toolkit. Also before you start writing your code, you may want to see/refer other examples built around your requirememt.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
Message 2 of 19
(10,006 Views)
After looking what you told me, I made a few changes and decided to start again.
I got an error, and I can't figure it out how to fix.
Can you please take a look and see what I did wrong? And how can I fix it?
Thank you
Message 3 of 19
(9,981 Views)
Input Stream = 0...1
WaveForm to Binary U16 Array = Value Range ->  0...65535
Try something like this:
DWDT WaveForm to Boolean Array   For Loop [Indexing]  Boolean to (0,1)  [Concatening]
Message 4 of 19
(9,954 Views)
I cannot open your code right now but seeing to the error message it is clear that the input bit stream (array) that you're feeding to 'MT modulate FSK.vi', it also contains elements with value other 'zeros' & 'ones'.
Message 5 of 19
(9,951 Views)
This seems to have worked. But how do I go back to digital?
I am trying to modulate and demodulate.
Thank you!!
Message 6 of 19
(9,934 Views)
Here it is the Conversion Logic.
Example Attached 😄
Message 7 of 19
(9,921 Views)
Just one little modification.
Message 8 of 19
(9,892 Views)
Thank you.
But can you please tell me where to find the second function that converts from dynamic data type to analog waveform?
You uploaded a VI using 2012 and I cannot open because I have a 2011. And I cannot seem to find this function.
Message 9 of 19
(9,878 Views)
From Dynamic Data Type (DDT)
Message 10 of 19
(9,872 Views)
