03-25-2013 04:36 AM
I am using a PXIe 7962 Flex RIO module with a 5781 adapter module. I have multiple bit files that I want to load pragmatically. All the bit files have the same clocks and FIFO's. Is there a way to load the bit files dynamically at run time based on the user action?
Thank You,
Sharath
03-25-2013 06:14 AM
Yes, you can have multiple instances of "Open FPGA VI Reference", each one linked to a bitfile. Place them in a case structure and load the desired one. Make sure to have "Dynamic mode" checked in the Open FPGA VI Reference properties, else the references don't match.
03-25-2013 06:34 AM
As has already been said, you can open/change your bit files as much as you want. Just remember that you can only have 1 bit file (FPGA personality) loaded at a time.
