Hi Ray,
You need to have the "FPGA Module" in LabView so you can make an "FPGA project". You may also need the Digital Filter Design Toolkit
Once you do that go to your project and
> XXXX Target
> Chassis
> FPGA Target
- right click here and go to "Start IP Generator"
- "LMS Adaptive Filter" is under "Adaptive Filters"
Once you choose your parameters, LabView generates FPGA code for you.
I apologize if this is overly pedantic. I am relatively new to LabView (and FPGA coding!)
-Danish
