Hi Bill,
I just want to make sure that I am understanding this correctly. You have an FPGA VI that you are trying to control inside an Action Engine. If you don't control it inside the Action Engine, then the main VI works fine. However, if you do try to control it inside the Action Engine, then it causes LabVIEW to crash, producing the cpp error. Is this correct? Also, once that happens, the main VI does not seem to work correctly, right? Does this cpp error occur when you hit the run arrow or when you are editing the VI? Is there a possibility that you could post the VI on the forum or at least a screenshot of it? That might make things a bit clearer.
