Under LV 8.5, when I compile my FPGA VI, sometimes it works and sometimes not. It might fail the first time, but work the second or third time with no changes to the VI. When it fails, I get the following text in the Compilation Failure dialog box.
Release 9.1.03i Xflow J.33
Copyright (c) 1995-2007 Xilinx, Inc. All rights reserved.
xflow.exe -p xc2v3000-4-fg676 -synth vhdl_area.opt -implement balanced.opt
-config bitgen.opt C:\NIFPGA85\srvrTmp\LOCALH~1\CRIOPR~1\toplevel_gen.prj
ERROR:Xflow:198 - Design C:/NIFPGA85/srvrTmp/LOCALH~1/CRIOPR~1/toplevel_gen.prj
doesn't exist, or design extension is not valid.
ERROR:Xflow:11 - 1 error(s) found while processing cmdline arguments.Aborting
flow ....
ERROR:Xflow:38 - Command Line errors... Aborting!
I'm working off a network, and keep my project on a server, if that makes any difference.
-Ron
