i have an application with the compactRIO and i'm using the labVIEW FPGA Mode , i have 3 VIs one for the FPGA , one for the Real Time and the last on MyComputer , the problem is when i launch the MycomputerVi the others VIs are not runing ; so how can i launch all the VIs only from the Host from MyComputer
Well, the RT VI runs on the cRIO. You can make the RT VI load the FPGA VI. But you will need to start up the RT VI separately from the Windows machine since it needs to be uploaded to the cRIO.
There are only two ways to tell somebody thanks: Kudos and Marked Solutions Unofficial Forum Rules and Guidelines "Not that we are sufficient in ourselves to claim anything as coming from us, but our sufficiency is from God" - 2 Corinthians 3:5
