FPGA and External Clock Source
I am new to FPGA world and trying to use an external clock for NI PXIe-1073 that has a PXI-7851R IO. I tried to feed the clock signal using a digital input, but the digital input does not show up in the clock options of time loops in labview FPGA.
I would appreciate it if you could help me in this issue.
Masoud
(3,328 Views)
Hey Masoud_A,
Take a look at this forum post for some more information on this:
https://forums.ni.com/t5/Real-Time-Measurement-and/Timed-Loops-with-External-Clocks/m-p/2209902/high...
The short answer is that this is not supported on our R Series cards. However, the workaround posted in that forum post should be a good start.
Cheers,
Ryan C.
(3,236 Views)
Hi Ryan,
Thank you for your answer. I checked that forum and I don't think using a SCTL to sample the external clock into a local variable will provide the accuracy that I am looking for. Is there any new IO that provides an external clock option?
Masoud
(3,229 Views)
Hi Masoud_A,
What do you think about sampling and then using the case structure without a local variable?
The forum post is also up-to-date about the I/O. There aren't currently any R Series or Compact RIO devices that support the external loop timer.
Cheers,
Ryan
(3,207 Views)
