09-19-2014 10:52 AM
I get the following error right at the beginning of the compilation :
LabVIEW FPGA : An internal software error in the LabVIEW FPGA Module has occurred. Please contact National Instruments technical support...
niFPGACompile_Dialog.vi
<APPEND>
<b> Additional Information:</b>
<b>Original error message: </b>
Error - 61457 occurred at niFpgaCompileDialog_GetStatusFromFile.vi
Possible reason(s) :
LabVIEW FPGA : The compilation status file is missing or currupt.
Complete call chain :
niFpgaCompileDialog_ParseJobList.vi
niFpgaCompileDialog_Dialog.vi
I tried desinstall all National Instrument software and reinstall them and still get the same message prior to compilation. Didn't find any post on this error.
Anyone can help?
Thanks a lot!
09-23-2014 10:57 PM
C:\Program Files (x86)\National Instruments\LabVIEW 2013\vi.lib\rvi\CDR\niFpgaActiveJobList.txt
After that, uninstal the older version of Xilinx Compilation Tool.
Hope this can help you.><
09-09-2015 12:19 AM
This reply is a little late (1 year). I experienced the same issue today. I was developing some new FPGA VIs and labview 2013 crashed repeatedly in the process (unknown reasons). Eventually I was not able to compile any FPGA VIs, even ones that I had previously compiled . I got the same error as you (I've attached my screenshot).
pigeonjen 's solution almost worked for me, but copying the text 'as is' in the reply did not work. Fortunately I have another workstation with the same versions of labview installed. So I was able to copy the niFpgaActiveJobList.txt file from that computer to the computer that was experiencing the error. I was able to compile FPGA VIs afterwards. I did not reinstall xilinx tools or anything else. I've attached the text file to this reply.
01-25-2016 12:02 AM
the same problem has occured to me recently and it confused me many days. The solution you put forward resolved my problem perfect. thank you very much
