FPGA Boolean Size in Memory
LabVIEW stores booleans as a U8 in memory according to the article.
http://zone.ni.com/reference/en-XX/help/371361J-01/lvconcepts/how_labview_stores_data_in_memory/
My question is what happens when you develop in FPGA? Specifically if I made 8 lookup tables with the data type being a boolean, does that take the same amount of resources as a single U8 lookup table? Or is it taking as much resources as 8 U8 lookup tables?
Message 1 of 12
(3,362 Views)
I am not 100% sure, but I believe on FPGA a boolean is actually treated as a bit, not a byte. The u8 representation is due to a byte being the smallest addressable unit in a PC type environment. (At least I think this is correct. Someone smarter than me may say otherwise).
Message 2 of 12
(3,359 Views)
Accepted by topic author Hooovahh
HERE you can find out exactly how much space is used by different things on the FPGA target.
Normally a logical X-bit structure consumes X bits since FPGA has no limitations in this regard.
Shane.
Message 3 of 12
(3,312 Views)
Nice resource, Intaris.
I'm interested in the resource utilization statistics for a Spartan 6, LX 45 (sbRIO-9606). Is that available somewhere else? Should I deduce them from any of the attachments included in the link you provided?
Thanks!
Message 4 of 12
(3,196 Views)
Most can be found on the Xilinx website:
http://www.xilinx.com/publications/prod_mktg/Spartan6_Product_Table.pdf
David H.
Message 5 of 12
(3,165 Views)
These are the device resources.
What would be great is to have resource utilization charts for more targets.
A few more details in the resource utilization charts would also be nice, e.g. "Scale by Power of 2" is free (uses no resources) when the power is a constant (afaik). How about Index Array when a constant is wired to the index input? What about Rotate?
Message 6 of 12
(3,150 Views)
The LabVIEW help states that Index Array and Rotate 1D Array take no clock cycles when constants are used.  Perhaps you need to have the FPGA module installed, but I see these details at the end of all the relevant help pages.
Message 7 of 12
(3,135 Views)
I'm aware of this, but I think it would be helpful if this information is reflected in the device utilization statistics.
I was not talking about rotate array, just the plain Rotate (for integers). It does not say anything about a constant wired to 'y'. The same for "Logical Shift".
Message 8 of 12
(3,087 Views)
Hi dan,
the LabVIEW help says this about FPGA device usage of Rotate:
(atleast in my LV2011 with FPGA module…)
Message 9 of 12
(3,085 Views)
Thanks, I know, but I wonder if this is true. I would hope it's free when wiring a constant to y (since in this case it's a pure wiring operation).
Message 10 of 12
(3,079 Views)
