05-26-2010 05:10 PM
I am trying to update an exe that communicates with a NI-FP-1000 through MAX. I am using Labview 8.6.1, I have updated Max to 4.6.2 and updated the Fieldpoint to 6.0.6.
The development suite is on my windows XP machine. I create the exe and Installer on XP. I am then installing the exe with MAX onto a WIndows 7 machine.
The problem I am having is with the configuration in MAX. I have an FP-1000 connected to a FP-TB-10. When I load my configuration .iak file it does not show the FP-TB-10. If I have MAX find devices the FP-TB-10 shows up. I then save the iak file and reopen MAX with that file and the FP-TB-10 has disappeared again. Does anyone know how to resolve this issue? Is this something that will require going to Labview 2009?
Thank You.
05-27-2010 05:18 PM
06-03-2010 04:58 PM
06-11-2010 07:32 AM
06-11-2010 02:59 PM
Not exactly the same but...
I was having similar problems under LV-DSC 8.2 about a month ago. I also was not using the serail version of FP but rahter a FP-2000 or something close. I was have major trouble getting the configuration to "stick". I ended up hitting every save I could find in MAX (noral save FP save) and left MAX and re-opened after each change.
Eventually I go them to stick. It just seemed that it would not save more than one change at a time.
Ben
06-11-2010 03:38 PM
Ben,
I can give that a try. I problem is that I have many customers out there using this, all over the country, and I can not have them doing this process.
I currently have a customer that pointed this issue out to me, I will see if I can get it to save and then send the file to him and see if it works.
This issue started with MAX 4.5, I then updated MAX to 4.6.2 to see if that resolved it, but the same issue.
Thank you for the response!
Paul
06-14-2010 04:52 PM
06-22-2010 09:37 AM
I am having a similar problem. I have a system that was running FieldPoint 6.0.5 on XP and the iak loads correctly in XP. I installed a new host pc running Windows 7 32-bit and I installed FieldPoint 6.0.6f1 and now 2 of my 4 Fieldpont units do not show up in MAX. Unfortunately the 2 that do not show are running counter modules in which I have a lot of channels created. So simply finding devices is not a good fix. Any help would be appreciated.
I am running 3 FP-2000 and 1 cFP-2020. The problem is on one FP-2000 and the cFP-2020
06-22-2010 09:57 AM
@ClutchProgrammer wrote:
I am having a similar problem. .... Unfortunately the 2 that do not show are running counter modules in which I have a lot of channels created. So simply finding devices is not a good fix. Any help would be appreciated.
The counters and timer attribute channels etc made it very painful on my side as well.
But the issue of getting changes to "stick" was not limited to the counter timers but all setting channle names etc.
Thank you for confirming!
Ben
06-22-2010 10:01 AM
I can't seem to update the software on the units either (from the Win 7 machine). When I go to add/remove software in MAX nothing is available. It's been a while since I used these systems so I might be forgetting something.
