10-05-2009 12:28 PM
Hi
Im trying to figure our the noise in a laser. My set up is Laser- Detector-Oscilloscope. I read the signal using a GPIB and Labview program. I think I need to take the FFT of the signal produced but it does not give me anything. I wired the output signal to the FFT.vi and the result is one peak at 0 (zero). I should al least see a peak around 60 Hz(room light) but I dont see it. My sampling rate is 100Ksamples/second. Also, how can I see frequency on x-axis of the FFT plot and what is the Y plot on FFT chart?
Thank you
Solved! Go to Solution.
10-05-2009 10:43 PM
10-05-2009 10:45 PM
10-06-2009 10:46 AM
Thank you for your reply
Ive used the spectral analysis, Im attaching thefront panel and the block diagram. I still cannot see frequency of the rom light.(frequency numbers are changing from 0.1 to 0.4) Is that the Hz unit?? why? Again my set up is Laser- Detector and Oscilloscope and the scope is connected to the computer using a GPIB interface.
Thank you so much
10-06-2009 10:54 AM
10-06-2009 11:02 AM
10-06-2009 11:28 AM
10-06-2009 12:46 PM
so I builded a waveform and put dt and Y (signal) and fed that into spectral analysis. Also I put a chopper on the way 100 Hz frequency to be able to see the signal. Now I should see a peak at 60 Hz, 120 Hz(room light) and the signal around 100 Hz. but I see nothing. The sample rate is 250 Ksamples/second because oscilloscope decides the sample rate. If I let the time/division to be 20 ms then to be able to collect 50,000 data points the sample rate should be 250 Ksamples/second. whatever the sample rate is the oscilloscope wants to collect 50000 data points. Could you please help?
Thank you
10-06-2009 01:59 PM
Hi again
I think I figured it out, I can see the chopper frequency now, but I cannot see the room light still. But part of the problem is solved. Thank you very much
08-13-2010 07:42 AM
could you share what your solution was? I'm having a similar problem. Or does anyone have a better idea for how to take an FFT of an array of data (I have one 1D array of time data and one 1D array of the corresponding F(t) data). I interpolated the dataset so that everything is spaced equally and then built a waveform and fed it into the spectral analysis express vi but get the same noise-like signal shown in the jpeg in the previous post. I've also tried the regular FFT vi, but I'm not sure what the 'bin' number corresponds to - it seems really strange to me that you only input the dependent variable and only get the dependent variable out - to me it would make more sense to input the dependent variable and the independent variable and then get the transformed dependent variable plus the 'frequency' out. Any suggestions?
