12-03-2012 06:57 AM
Hi guys,
I have a question about using the express daq function and cluster management.
I need to sample from ni 6501 from ports 1.4..2.7 total of 12 Inputs.
So with the express DAQ Digital input (line) option I'm selecting Ports 1.4..2.7 total of 1 lines.
Then I want to convert the sample to cluster and unbundel io 12 samples....
The problem is that when I'm doing unbundel I see only 10 samples of (T/F)
Any ideas?
Pic attached.
12-03-2012 08:16 AM
Hi not need to answer i ave found the sulotion in setting the cluster size at the convertion.
12-03-2012 12:15 PM - edited 12-03-2012 12:33 PM
The conversion of an array to a cluster to unbundle individual elements has unnecessary steps It is a Rube Goldberg.
Just use Index Array. Drag the bottom of the Index Array Function downward and you will get multiple outputs. By default, the first is element zero, and the rest are all in sequential order.
