Exporting states from a case and event structure to a text file
I need this for documentation. Is there a way to export a list of states from a case and event structure to a text file? Thanks.
(2,587 Views)
Steve,
If you enable scripting you can do it like this:
Then write the names to a file.
Enable scripting nodes under tools>>options>>vi server
Dont forget Kudos if this is what you were looking for Smiley Happy
Michael
(2,580 Views)
You can do this for a case structure.  You cannot do it for an event structure.  I know of no programmatic way to get event structure names/events.
(2,572 Views)
I guess the property is not available for events because they are not simply case labels. My workaround for now will have to be the old fashioned print screen and ocr. I tried this out and it was better than typing, but far from elegant!
Michael
(2,562 Views)
I've (somewhat) succeeded using OCR to retrieve the events from an Event structure here.
Jim
(2,545 Views)
