NI Home
Cart Cart | Help
You are here:
Reply
Active Participant
Steve_Block
Exporting states from a case and event structure to a text file
I need this for documentation. Is there a way to export a list of states from a case and event structure to a text file? Thanks.
Member
RiversDaddy
Re: Exporting states from a case and event structure to a text file
Steve,
If you enable scripting you can do it like this:
Then write the names to a file.
Enable scripting nodes under tools>>options>>vi server
Dont forget Kudos if this is what you were looking for :smileyhappy:
Michael
Trusted Enthusiast
DFGray
You can do this for a case structure.  You cannot do it for an event structure.  I know of no programmatic way to get event structure names/events.
Using LabVIEW 2009 - 2012 on Windows 7 64-bit
Member
RiversDaddy
I guess the property is not available for events because they are not simply case labels. My workaround for now will have to be the old fashioned print screen and ocr. I tried this out and it was better than typing, but far from elegant!
Michael
Active Participant
jcarmody
I've (somewhat) succeeded using OCR to retrieve the events from an Event structure here.
Jim
CLD
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
