Export data in Excel format
I'm a little beginner in labview and for a project, i have to make a measurement program.
All is good but i have some difficulties to export the data.
I want to export organized data in Excel. I'm going to be clear:
I want to have data in colum with the legend at the top (for example, in the box A1 there is "frequency" writen and the rest of the column A is the values of the frequency, then in the box B1 there is "Spectrum" writen and the rest of the column B is the values of the frequency  spectrum,....).
There is an other thing. In the measurement program, it'a possible to write a commentary. I would like to export too the commetary on an other sheet of the excel file.
For the moment, the only thong that i can do is to export only the datain column.
There is somebody who can help me?
Thanks a lot.
PS: all the data are a 1D array.
(2,368 Views)
Please find the attached VI snippet.
I hope this will solve ur purpose.
I have used a template fro excel report.
Please use attached template.
Pankaj
(2,356 Views)
Thanks for the help but i don't have the "Excel add worsheet.vi".
Is it possible to have it (i dont find it free on internet).
Thanks a lot
(2,322 Views)
It is not free. It is part of the Report Generation add-on.
You can do all of the ActiveX stuff yourself. There are numerous examples in the Excel Board. As an alternative, you can use one of file write functions to create a text file. Use a comma or tab separated file and Excel can import it. The only thing you cannot do with a text file is assign your comment to a separate worksheet.
(2,312 Views)
Ok,
i think i'm going to do the thing diffrently. Instead of open a new sheet, the commentary and the data will be in the same sheet.
I'm going to see if it works.
Thanks for the answers.
(2,299 Views)
Have you tried creating a TDMS file? Here is an example of a program I have pulling data from 3 different devices.
(2,294 Views)
Finally,  the first program doesn't works without the report generation toolkit.
i'm going to see if it's possible with the tdms files.
(2,273 Views)
