03-18-2015 10:30 AM
Hi, is possible to launch app created in Labview outside Labview?
03-18-2015 10:40 AM - last edited on 03-21-2024 11:08 AM by Content Cleaner
03-18-2015 10:47 AM - edited 03-18-2015 11:04 AM
I see, it is only in Professional version. I own the student edition so one solution is upgrade to professional edition, isn't it?
03-18-2015 11:02 AM - last edited on 03-21-2024 11:09 AM by Content Cleaner
Application Builder product page.
The Application Builder is NOT free. You can purchase it separately as an add-on.
However, it is included in the LabVIEW Professional Development System and I believe some of the industry-targeted suites.
Also note that executables built require the LabVIEW Run-Time Engine to be installed on the target for them to run in.
03-18-2015 11:06 AM
OK. Thank you Vltan.
03-18-2015 12:32 PM - last edited on 03-21-2024 11:09 AM by Content Cleaner
The student edition is for personal educational use, not to build applications for distribution. Even if you would buy the applications builder, you would probably use it outside the allowed scope. If you want to share code with your student peers, they most likely also have the student edition. (Or they can easily get it. Note that the Student edition is free as long as you are a student).
Another solution would be to run your program on one computer in the development system and operate it from other computers using a web browser.
What exactly do you have in mind? If this is for research, see if your department has a license. You should not use the student edition for that.
03-18-2015 12:38 PM - edited 03-18-2015 12:39 PM
Hello, I understand to you. It is for school project...
