07-02-2015 01:46 PM
07-23-2015 09:53 AM
Hey, I hope this finds you all.
I got the vi to export data to an excel sheet, but it "only" exports 500 points. My sample rate is 10,000 a second. Is there any way to increase the number of points it exports?
Thanks.
07-23-2015 10:36 AM
What is it using to export the data? Did you acquisition fill up at 500 points? That's only 1/20th of a second of data. Still not enough information here because there are so many different ways to save/export data.
Congrats on getting it to work a bit.
Cheers
--------, Unofficial Forum Rules and Guidelines ,--------
'--- >The shortest distance between two nodes is a straight wire> ---'
07-23-2015 10:58 AM
Thanks for the help.
I actually have a different question maybe you can help with. On my desktop the program exports to excel fine, but when I do the same thing with the same export data to excel node on my laptop. No excel file opens up. I don't understand why the laptop is different when I did the same thing on both computers. I know not much info is given again.
07-23-2015 11:10 AM
07-23-2015 12:45 PM
Please, please, please do not use unexecutable Pictures of code. We cannot "test" or modify a picture, and you can't reasonably expect us to hand-code what you show in a (usually reduced-in-size) image.
Learn to use the Error Line (which almost all NI Functions expose -- it's there to be used). Not only will it help you pinpoint errors, it will show you (and others) where code is serialized (emphasizing Data Flow), where it is parallelized (if that's a word), because you have parallel Error Lines, and would have prevented the previous comment about the "dangling" whatever-that-node is on the right.
07-23-2015 01:51 PM - edited 07-23-2015 01:52 PM
Cheers
07-23-2015 02:43 PM
Very good, self-referential, even! Bob_Schor is pleased ...
Mysterious Stranger
07-24-2015 08:19 AM
Sorry guys. Again, I can't share the code due to sensitive information. I'm editing someone else's code and cannot access a lot of the subvi's. I wasn't sure if this was a simple or common problem that could be fixed. It's not so don't stress over me not sharing any code.
Thanks for trying. I know yall have your hands tied with this, but the little pointers are helping.
Neil
07-24-2015 08:50 AM
Really, it looks like it IS simple.
You run the invoke node in parallel to your while loop and run the invoke node only once. It's no surprise you're not getting all of your data.
