02-01-2007 12:28 PM
02-01-2007 12:36 PM
02-01-2007 12:44 PM
02-01-2007 12:50 PM
Here it is. Thanks for looking this over.
- Mike
02-01-2007 01:20 PM
02-01-2007 01:21 PM
02-02-2015 10:25 AM
Hi
i saw your post and found out that you have successfully been able to convert the exponential string to the decimal number. However, I've not been able to do it. So could you please help me out with it. I want the current values to be like 1.4528576, while now am only getting the integer values.
Thanks for the help.
02-02-2015 12:26 PM - edited 02-02-2015 12:26 PM
Either your input to the function is wrong, or your method of displaying the output is wrong, the fucntions works fine unless you can show it not working properly.
Please post an example of it not working, with inputs as a constant.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
02-02-2015 12:57 PM - edited 02-02-2015 12:58 PM
Sitank wrote:i saw your post and found out that you have successfully been able to convert the exponential string to the decimal number. However, I've not been able to do it. So could you please help me out with it. I want the current values to be like 1.4528576, while now am only getting the integer values.
Please run your VI until the string array labeled "Current" contains 10 valid elements. Now right-click the "Current" terminal and select "create constant". Save under a new name and attach it again (and please give it a reasonable file name!) Now we have something to play with.
Could it be that the device uses a comma as decimal seperator? What is the language setting of your computer?
02-03-2015 06:12 AM
Thanks for the help, but am done with my issue... 😄
