03-05-2012 01:37 AM
Is it possible to implement debugging facility using Win32 OutputDebugString() API's in LabVIEW?
03-05-2012 04:33 PM
I don't really see how, as there is no debugger, per se, in LabVIEW in the sense that that function expects.
03-05-2012 09:12 PM
What I meant is, the LabVIEW application should keep posting messages using the OutputDebugString() API so that some debugger program like Dbwin32 can capture the messages and display it. If that can be implemented, it will serve as a mechanism to observe what the LabVIEW application is doing now and also it will behave like a probe so that we can utilize it as a debugging tool.
03-05-2012 09:58 PM
Well, I suppose you can try calling it using the Call Library Function Node. The prototype for it is pretty simple - it just has a single string input.
03-05-2012 11:06 PM
