01-08-2007 10:06 AM
01-08-2007 10:09 AM
You can easily have multiple loops running at the same time. LabVIEW takes care of the threading for you, so each VI may be running a large number of parallel threads at the same time.
Take a look at the producer consumer templates to see a good usage of parallel loops.
01-08-2007 10:15 AM
01-08-2007 10:17 AM
Its really hard to say without seeing your code. Go ahead and attach it so we can all help you easier.
01-08-2007 12:19 PM
I agree with Evan that without the code this will be hard to answer, but as a guess - If the loops are connected with a wire, then loop B will have to wait until loop A finishes running completely.
To learn more about LabVIEW, I suggest you try searching this site and google for LabVIEW tutorials. Here, here, here, here and here are a few you can start with and here are some tutorial videos. You can also contact your local NI office and join one of their courses.
In addition, I suggest you read the LabVIEW style guide and the LabVIEW user manual (Help>>Search the LabVIEW Bookshelf).
