01-16-2007 07:34 AM
01-16-2007 08:03 AM
01-16-2007 08:28 AM
@Jhoskins wrote:
Are you working with large arrays. You may have a memory leak (ie a continuosly growing array). Try enabling debugging and building the EXE with debugging enabled and see what happens. If you can post the code so that we can have a better look and know more about what we are dealing with.
I can't post the source files, but I can tell you that I'm am doing a lot of data calculations and also collecting data from another sensor using Datasocket (page handling). So a memory leak is posible but unlikly because I try to pay close attion to potental problems like that. but none the less I will look around and see if I find something like that. thanks for the help and if you have any other ideas please don't hesistate to shoot them my way.
In this app. I'm using: Datasocket (Both the page method and binding controls to a OPC Server source) Report toolkit to write excel files and config files and thats about it... it's not very complicated just has allot of data and alot of calculations to perform
Thanks for the help
Matt
