10-12-2013 04:57 AM
Exe compiled in LV 2010 crash - Since installing LV 2012 SP1 and 2013
Double-click on exe icons (LV apps written in 2010), the application icon appears on taskbar then disappears (program crashes).
I have tried re-installing the exe's but doesn't fix. Is there an issue with the new LV RTE's?
Any suggestions for fix???
10-14-2013 09:35 AM
10-14-2013 09:44 AM
battler,
Have you tried making your exe into a debuggable exe? You can do this through your project build specification Advanced>>Enable Debugging. Make sure you check the box for Wait for Debugger. This means when you launch your exe you can connect to it from LabVIEW and see your block diagrams, use highlight execution, probles etc. It is quite possible that you are running into an error case while your program is loading and it is exiting.
Jeff Peacock
Product Support Engineer | LabVIEW R&D | National Instruments
