Exception occured in Microsoft SQL Server Native Client 10.0: Login failed. The login is from an untrusted domain and cannot be used with Windows authentication.
I am using UDL file to connect to SQL server. Using UDL file I am able to connect to database but when I am using same file in labview to connect, I am getting above message.
Attached UDL file for better understanding
Suggest how to make it work.
(WIN-7, SQL-2008,LV-2011)
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(3,376 Views)
Your connection string is telling SQL Server Native Client to use NTLM/integrated security. You need to use SQL Server authentication (i.e. username/password.) See http://www.connectionstrings.com/sql-server/ for examples.
(3,359 Views)
I am using ID password to connect.I am not sure why it was not there in UDL.
--Ranjeet
(3,352 Views)
