07-28-2006 06:33 AM
07-28-2006 12:22 PM
What you're looking for is not possible with any of the VIs in the Report Generation Toolkit, but you can do it with ActiveX. In fact, someone just posted a VI (perhaps not coincidentally?) to the "Excel" thread in the Breakpoint forum that does this:
http://forums.ni.com/ni/board/message?board.id=BreakPoint&message.id=2391
Hope this helps,
-D
07-28-2006 01:00 PM
07-29-2006 02:17 AM
hi,
Thanks for your suggestions, i need same Print Preview option which is in Excel, it is ok if it possible to call that Print Preview option from Excel, Expecting Suggestions.
Suresh S
07-31-2006 10:16 AM
Suresh,
The key to displaying the print preview screen is in ActiveX just like Darren said. I wrote a quick program that opens an ActiveX reference to an excel file and then shows the print preview.
I hope this helps,
Justin D.
08-01-2006 01:21 AM
08-01-2006 01:36 AM
hi justin,
Sorry for my previous message, it was working in L7.1 also, since First sheet of excel is empty that problem occurs, now it is ok..Thanks for your support.. this really solves my problem
Suresh S
08-01-2006 04:27 AM
08-01-2006 09:47 AM
hi partha,
I have send the VI which i converted from L8.0 to L7.1..See attachment
Suresh S
09-13-2010 03:21 PM
Hi, all.
I'm interesting in showing an Excel print preview of a previously generated report, but I'd like to display it on an embedded ActiveX control. Do you know if it's possible? I'd like also to manipulate this preview window, remove the upper buttons, and transfer their functionality to LabView controls.
If not, do you know an alternative way of showing a report preview on the LabView front panel?
I've tried with a PDF display (see Display PDF in Dialog box in LabVIEW). It's almost perfect, but I can't find a way to remove menu toolbars or disable the run-time menu that it's part of the PDF reader application.
Any suggestion?
Francisco
