09-02-2005 09:01 AM
09-02-2005 12:46 PM
09-06-2005 06:30 AM
09-06-2005 06:52 AM
Hi
Have you tried to open another excel application and use that at the same time. Our problem occurs in the same workbook were
we try to 'open' an other sheet which the application uses to update screen etc.
Possible idea would be for application to dump data to text file, every 15 minutes dump to new text file so that possible to analysis
data whilst logger records cyurrent data. The15 minutes is just an arbitrary value.
chow
xseadog
09-06-2005 08:56 AM
09-06-2005 12:39 PM
It sounds like you are trying to use Excel to perform analysis of the incoming data while the data is being logged. ActiveX control is immediately disabled when any changes are made to any Excel object on any worksheet of any workbook. Control will resume when the editing is complete.
I recommend that you include the analysis in an Excel template and log the data in another worksheet. Log your data to Sheet1 and create charts for analysis in Sheet2. Just provide ranges for the chart to include the whole column of the source (ie. Sheet1!C:C). Every time you view the chart on Sheet2, it will be updated to show all data collected.
You can also create your chart in another workbook, reference the logging workbook and open the second workbook before the data collection begins. If you regularly write the data to disk, just open the workbook READ-ONLY from another computer on the network to perform analysis of the snapshot.
