02-07-2017 01:13 PM - edited 02-07-2017 01:28 PM
I changed the VI to the one I'm actually using.
I think the subject line says it all. Here's my data collected from a test instrument.
Here's what I get in Excel.
Solved! Go to Solution.
02-07-2017 02:53 PM
02-07-2017 03:32 PM - edited 02-07-2017 03:41 PM
@ben64 wrote:
It is just the way it is displayed in Excel, if you click on a cell and look in the formula bar you will see the real value.
Unfortunately, at least in LabVIEW 2016, this isn't correct. LabVIEW takes a perfectly good polymorphic function (Excel Easy Table), accepts the Dbl format, but then internally hands it to a function called "Append Numeric Table to Report (wrap)" that includes an (unwired) Format String, %.3f, that limits you to three decimal places. You really do lose the precision [I just "did the experiment" to prove it to myself, but will leave as an "Exercise for the Reader" if changing the Cell format changes this behavior].
Aha! Solved it. Don't use "Excel Easy Table", but instead use "Append Table to Report", which (as it turns out) is the function that Easy Table calls, but now you can specify %6.3f as the Format you want and get the Excel appearance you desire. It still isn't saving Dbls (why not?), but you can at least control the Precision.
BS
02-07-2017 03:40 PM
That's terrible!!! I don't have the time to try but I wonder if saving the data as a string table and then changing the cell format in Excel would be possible.
Ben64
02-07-2017 03:42 PM
Ben,
I was editing my reply as you were responding to it. It's partly solvable, but still a kludge.
02-08-2017 08:15 AM
I want to try the Append Table to Report but I don't know how to build MS Office parameters. Help!
02-08-2017 09:31 AM
It is not clear (to me) why you need to worry about the MS Office Parameters. Why don't you put together a small VI that shows what you are trying to do (and if you are unsure how to do something, put a Text Label in there that says what you want to do). Seeing actual code, with inputs, outputs, etc., makes it much easier for "non-mind-readers" such as myself to better understand what you want to do and where you might be going astray. I can pretty much guarantee one of us will respond within a few hours.
02-08-2017 09:38 AM - edited 02-08-2017 09:52 AM
OK so I got something for that but I'm getting this error when I run it. I'm including a piece of the VI. In the end, I need to collect data from an instrument, insert it into a spreadsheet, take another set of dat and insert into the same Excel sheet at the new location next to the previous data. I had everything work except the data being rounded.Here's
02-08-2017 10:03 AM
02-08-2017 10:09 AM
Tried that and got this.
