10-28-2015 10:15 AM
nyc,
I will overview what happened:
10-28-2015 10:37 AM - edited 10-28-2015 10:40 AM
@DrNO23 wrote:
nyc,
- My EXCEL installation is done via a packaged file from my University
- I began using ActiveX with EXCEL to import and export data however I was simply copying the property and invoke blocks along with the ActiveX Refnums from other VI's I found on the internet WITHOUT linking them to the Object library on my computer. (Someone who knew what they were doing would have placed a Refnum on the VI, pointed it to the Excel Object Library, and then derived all of the invoke/property blocks by wiring and selecting the methods/objects respectively.)
- I posted on the forum asking simply the steps required to get the VBProperties block since I had no idea where my problem was.
- You responded with the fact that (A) I needed to learn how to represent VBA in LabVIEW or (B) there was an error associating my blocks with the Object Library
- I did research and found that when placing the Automation refnum you must associate it with the Object Library, but mine wasn't found in the dropdown list of accessable libraries.
- Upon further digging I found that the Excel Object Library is packaged into my EXCEL.exe file and all I needed to do to access it was point my Automation Refnum to it
I still don't understand what you mean by a packaged file.
Which version of Excel? Yet again, you don't supply this information.
And yet again no VI from you.
Your Excel Object Library is packaged into your Excel.exe? I don't understand this.
All of this sounds very fishy.
Perhaps your university is doing something without actually buying/paying for Microsoft Office.
I have worked at several companies that use Microsoft Office, and I have never seen the behavior you are describing.
10-28-2015 10:42 AM
nyc,
EXCEL 2013
What version of Excel are you basing your assumption off? What is the filename of your Excel Object Library?
