08-10-2014 12:29 PM
I strange error I'm getting, both in LV2013 and LV2014 (I'm using the evaluation versions).
Opening the labview example finder kills my network connection permanently until I reboot. Then after reboot, the network takes a minute or two to come up, which is longer than normal.
Any ideas?
08-10-2014 03:08 PM
08-10-2014 03:17 PM
Hi Mike,
It's a new Windows7 laptop. Only had it a couple of weeks and no network problems until LabVIEW was installed. No, LabVIEW example finder has never worked on this machine. It's a wireless connection.
08-10-2014 03:29 PM
When the connection goes bad is there any change in its status in the Windows wireless manager? Does your laptop have a hardware wireless enable switch? If you turn you wireless off and then back on, anything different? Have you tried this with a hardwired network connection? Does it do it with any WIFI connection?
Mike...
08-13-2014 04:16 PM
Hi Mike,
Sorry for the delay, however I wanted to get a better idea of what was going on before posting.
I haven't tried this with a wired connection, but I have now identified the behaviour as follows:
1. Wireless freezes after 10-20 minutes of the computer being on. I don't even have to launch LabVIEW. Anything that tries to access freezes, e.g. Firefox never launches, a ping in a command window never returns etc.
2. Wireless still shows up as connected and with a signal. Running windows diagnostic on the connection shows no problem.
3. Disconnecting the wireless and reconnecting shows there is a problem- it shows as unavailable after trying to reconnect.
4. Uninstalling LabVIEW and all associated software removes the problem.
08-13-2014 04:51 PM
In addition to the post above, the LabVIEW uninstall froze at various stages saying it could not uninstall various NI associated services (sorry, I forgot to write the names down). To successfully uninstall, I set all the services to 'disabled (at startup)' and rebooted.
08-13-2014 08:17 PM
