11-12-2014 10:50 PM
Can someone please suggest an example VI for reading a touchstone data file (A__S_params.s2p) for me as a starting point. I want to get the magnitude and phase data of S21 to design a filter. I have tried to use Touchstone Data Plugin with the (DataPlugins - ATML) project from the LabVIEW example finder to first convert Touchstone file to TDMS format but have not been successful. Thanks.
Solved! Go to Solution.
11-12-2014 10:58 PM
Sorry I forgot to attach the data file last time. Here it is.
11-12-2014 11:32 PM
Still no data file. Seems to be a lot of that recently. Anybody at NI monitoring?
11-13-2014 12:37 PM
Hi Kathar,
The links below might be helpful for you:
http://www.ni.com/example/28433/en/
http://www.ni.com/example/31284/en/
AGJ
11-13-2014 12:56 PM
A touchstone file is really just a tab delimited text file with some header info.
11-13-2014 01:19 PM
Actually I've seen different flavors depending on the originator of the file. The Touchstone File Specification data line formatting rule just says that individual entries are separated by whitespace. HP-ADS separates the values with multiple space characters, the N5230A and C uses a single space character, the E5071C uses a single tab character. I usually replace multiple spaces or tabs with a single tab before processing the data.
Ben64
11-13-2014 08:22 PM
Ben64
That's the truth. I don't know why I said "tab" because I've seen different formats, too. The point I wanted to make was that ultimeately it's just a parsable text file. 🙂
11-13-2014 09:11 PM
I am grateful to all of you who have responded. I have downloaded the Touchstone Toolkit v1.00. Here are the instructions for installing the toolkit:
Installation Instructions
1. Place the Touchstone Toolkit v1.00 and the errors folders in the C:\Program Files\National
Instruments\LabVIEW 6.1\user.lib directory.
2. Restart LabVIEW to refresh palettes
3. Two new palettes will be added
Controls Palette- User Defined Controls sub palette : Touchstone Toolkit Palette
Functions Palette -User library sub palette: Touchstone Toolkit Palette
I have two questions:
1. Is there a more recent version of Touchstone toolkit? If so where can I find it from?
2. I am using LabVIEW 2013. In which folder I should place the above two folders so that two new palettes are added.
Thanks.
PS: I am having difficulty adding screenshots and files to these messages.
11-13-2014 09:17 PM
Put it in your corresponding user.lib folder. That's really neat that you dound a toolkit! It will probably work just fine. 🙂
11-13-2014 09:42 PM
I have just placed both the folders in the user.lib folder and have restarted LabVIEW. I can see both the palettes now with all the functions and controls. That should help solve my problem. Thanks to all of you.
Regards and best wishes,
Kathar
