Exact subVI of error when there are multiple instances of the same subVIs
Hi all,
I am getting a warning "Warning 200010 occurred at DAQmx Stop Task.vi:3590002". I am using error clusters. However there are several DAQmx Stop Task.vi's in my diagram. How do I know at which of those subVI's the warning/error was generated?
Thanks in advance.
Cheers,
Samuel
(2,843 Views)
Usually with probes and appropriate error a handling.  You would add in some code to state which task caused the error and put that information in the error cluster.
GCentral
(2,803 Views)
You can also modify the routine generating the error to include information that would help identify the particular I'll instance.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,779 Views)
