08-07-2014 08:55 AM
What happens in my code if I deleted Time out case in the event structure and run the code .
08-07-2014 08:58 AM
Easy to test...
The event structure will wait until one of the events that you defined occurs.
Regards, Jens
08-07-2014 09:01 AM
It will behave similarly to wiring a -1 to the Timeout... aka... it will not time out (it will wait until an event occurs).
08-07-2014 09:01 AM
If you haven't connected anything to the blue "Event Timeout" connector in the top left of the structure, the default value of it is '-1'. That means that the timeout event is never executed.
In this case, you can savely delete that case.
Norbert
